Old 02-24-2012, 10:03 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default OEM Steering Column to Floor Cover VS. Swivel Floor Mount
What should I use?? OEM Steering Column to Floor Cover or a Flaming River Swivel Floor Mount??
I'm swapping a Camaro 1999 dash into a 1969 Camaro. I will be using the 1999 column and I've cut off the floor/firewall mount bracket on the 1999 Steering Column, so that the bare shaft remains. Both columns are the same diameter at the bottom of the column. Which brace should I use?? I will be mounting the top end of the column shifted about 3/4" toward the passenger side from the stock location. And I'm planning to use the stock location for the bottom.
What are the benefits of using a swivel mount instead of the stamped steel two piece OEM style?
Also, the top mount for the steering column will be mounted to a 1-5/8" bar under the dash, so the column will be secured, no doubt about it!!
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
