Old 02-26-2012, 04:20 PM
Firehawk_McLeod Firehawk_McLeod is offline
Default ls1 brake swap on my 68 camaro... Which wilwood master cylinder bore? help
I Did a complete ls1 brake conversion on my 68 camaro. BUt i dont plan on running a brake booster due to the size of my cam. So which wilwood master cylinder bore should i go with. thanks for the help
Old 02-26-2012, 06:03 PM
Camaro Dave's Camaro Dave's is offline
wilwood 8555
Camaro-Daves.com
303-332-6379
Old 02-26-2012, 06:40 PM
Originally Posted by Camaro Dave's View Post
wilwood 8555
Camaro-Daves.com
303-332-6379
Ok thats what i thought... What kinda issues would i run into if i ran the 8556. 1.12 bore
Old 02-26-2012, 09:32 PM
Apogee Apogee is offline
Extremely high, hard pedal with a 1.125" bore unit and not a lot of brake torque due to low caliper pressures. Very bad idea unless you're running a hydroboost IMO.
I wouldn't recommend running the Wilwood #260-8555 1" bore MC with the LS1 F-body calipers unless you were running a vacuum booster, especially when considering the factory LS1 F-body setup is a 1" bore MC with a dual-9" diaphragm booster. A 15/16" bore unit (no Wilwood option that I know of unless you move to a dual MC setup) will net you about 12% more pressure and pedal travel over a 1" bore unit, 7/8" bore MC (#260-9349) will be about a 25% difference.
Pad compound counts for a lot, especially when running manual brakes, so it would help to know what you intend to run for pads.
Tobin
KORE3
www.kore3.com
