Old 03-10-2012, 05:00 PM
John510's Avatar
John510 John510 is offline
Default Moser Axle Install Questions
I have a Fab 9 with Moser axles. My moser axles need o-rings around the bearings. Is this the only seal that I will need? Ive seen online where there is an inner axle seal that goes inside the axle housing tubes but not sure if I use this on a Fab 9.
Do I need the inner axles seals also or am I good to go with just the rubber o-rings? Maybe some RTV around the o-rings before I tighten the t-bolts?
If I do need the inner axle seals does anyone know what size I need? I see there are 3 sizes online.
[SIGPIC][/SIGPIC]
Old 03-10-2012, 06:42 PM
badmatt's Avatar
badmatt badmatt is offline
The o-ring is all that it needs little bit of lube so you dont tear it, and dont over fill your 9" 2.5 quarts.
