Old 03-11-2012, 10:05 AM
r.friborg r.friborg is offline
Default Tall baljoints with guldstrand mod
Hi
I have a 68 Camaro.
I have performed the Guldstrand mod and wonder if there is any idea to switch from regular upper balljoints to tall ones.
The rest of the setup is hotchkis 2" drop springs, bilstein shocks, stock swaybar for now.
Steering is right now stock manual box. But I have a iroc 12,7:1 box that will be installed.
All joints are new.
Solid Globalwest subframe bushings.
I live in Sweden and are making a big order from Summit, should I order tall upper balljoints.
Bear trackers will be orderd to correct the bumpsteer problems I have.
Old 03-12-2012, 08:26 AM
David Pozzi's Avatar
For a race car, it would probably help. It will increase bumpsteer, probably beyond what the Baer trackers can fix. The stud isn't long enough. You will need flat upper A arms like the high clearence Speed Tech, or Power Performance.
http://www.PozziRacing.com
