Old 02-26-2006, 11:55 AM
newschool newschool is offline
Default Electric water pump on 454
Is anyone running an electric water pump. I have a 67 Camaro with a 454 and I am wanting to clean up the engine a little (makes the engine block look BIGGER). Does anyone know of any PRO's or CON's of an electric water pump before I go spend the money?
Old 02-26-2006, 02:20 PM
Speedster's Avatar
Speedster Speedster is offline
Pros - Space, no belts, cool very well at idle.
Cons - expensive, must wire properly, will probably need to change pulley configuration.
Meziere pumps are rated at 2,000 hours MTBF (mean time between failure) continous operation. That is an obscene amount of drive time. Years.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 02-27-2006, 02:11 PM
D Rock D Rock is offline
Don't forget more power. I'm going with one on my camaro.
Derek
Old 02-27-2006, 02:23 PM
Talking
More power is always good. I have found an electric water pump in Summit that pumps 40 gpm. On a hot day at a red light, I run alittle hot and this would probably take care of the problem and keep me from upgrading my cooling fan. Red Lights Suck!
