Old 03-15-2012, 12:56 PM
64mali's Avatar
64mali 64mali is offline
Default T56 swap help
I know this has probably been gone over a million times but I am having trouble finding answers to some of my questions. I currently have a 468 BB Chevy motor 2 piece main block with about 600hp. I have a turbo 400 in the car now but just bought a 2001 Camaro T56. I plan on cruising the car but will obviously drive it hard once and a while. I have a 12 bolt rear end with 4.30 gears and an Auburn Possi.
So here's my questions. I was looking to go with a Quick Time Bell Housing (part#RM-6023) but I have nothing else. I want to go with a 168 tooth flywheel and a reasonably priced clutch set up. I don't know which clutch and throw out bearing to go with. Are they all pretty straight forward, in other words can I just order an 11" clutch assembly and throw out bearing for a 2001 Camaro or do I need a special conversion type? I have heard a lot of good and bad comments regarding clutches and throw out bearings but most of the post I have found are pretty old so I'm sure there has been a lot of changes in parts for this set up. Any information would be greatly appreciated as I'm pretty much ready to start the install.
Old 03-15-2012, 01:44 PM
454SSguy's Avatar
454SSguy 454SSguy is offline
Quicktime should be able to help you out but I think you could go with clutch flywheel and PP setup for a Mark IV BBC. Just use the 26 spline clutch and PP. Quicktime housing should let everything mate up but I dunno for sure. If you use a McLeod b/h, you can use there flywheel, clutch and PP, and I know it will work.
Old 03-15-2012, 02:26 PM
64mali's Avatar
Thanks, I called Quicktime and they were'nt very helpful. In fact he gave me the wrong part number for the Bellhousing. Honest mistake I guess. So as long as I get a 26 spline clutch and pp it should work?
Old 03-15-2012, 02:52 PM
jocko124 jocko124 is offline
I think Hurst owns Quicktime. Give Jim Goodlad a call at Hurst Driveline Conversions Tech Service line. He's very knowledgeable and super helpful.
Lee
1966 Cutlass
The difference between truth & fiction: fiction has to make sense.
Build Thread:
https://lateral-g.net/forums/showthread.php4?t=31963
Old 03-15-2012, 04:23 PM
64mali's Avatar
Thanks, I will call him. I talked to a rep at Centerforce and he suggested I go with a Cenetrforce Flywheel pn#700-140 and part#DF612909 for the clutch and pp. It's a "new" dual friction 12" clutch thats supposed to hold better and is lighter ( in weight and pedal force ) than the norm. He said its rated from 650-700hp. He also said the factory hydraulic throwout bearing will work. Any opinions?
Old 03-15-2012, 08:08 PM
analyte's Avatar
analyte analyte is offline
Check the travel required to disengage that 12in clutch. Depending on what's required, i.e. McLeod's 12in clutch needs 1/2in, you may have to shim the T/O bearing.
Kerry
Old 03-15-2012, 10:49 PM
64mali's Avatar
I checked the website and there's no specs on clutch engagement. So if this clutch and pp will work does anyone have any tips on a throwout bearing...stock or aftermarket?
Old 03-16-2012, 05:01 AM
454SSguy's Avatar
Saw this, thought of you. was that gay?
http://ls1tech.com/forums/parts-clas...let-steel.html
Old 03-16-2012, 11:29 AM
64mali's Avatar
I think I got it figured out. Apparently the Quick Time Bell makes things pretty simple. As of now I'm going to use the factory throw out, 12" Centerforce Clutch and PP. Its all supposed to be fairly easy to assemble, just a couple checks along the way.I ordered a Master cylindar adaptor plate and heim joint from Jay over at Speed Tech who was a really big help. Thanks for the help, let me know if you have any other suggestions, I haven't ordered everything yet
Old 04-29-2012, 08:01 PM
xx_ED_xx xx_ED_xx is offline
IF you need any help with this i went thru this already and had about everything go wrong from the beginning.
[email protected]
