Old 03-20-2012, 09:33 PM
orangevert's Avatar
orangevert orangevert is offline
Default Headers and motor mounts 69 camaro LS1
What are you using for headers and motor mounts?
69 Camaro LS1 vette motor, T56, Smoothed firewall, Stock subframe
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 03-22-2012, 06:21 PM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
Steer clear of the dynatech long tubes, they sit way too low. I used the transadapt plates and mounts, they worked out fine.
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 03-22-2012, 10:36 PM
John510's Avatar
John510 John510 is offline
I used Stainless works headers and Energy plates/mounts. Everything fits perfectly.
[SIGPIC][/SIGPIC]
Old 03-23-2012, 06:00 AM
almcbri's Avatar
almcbri almcbri is offline
That is going to depend on your motor mounts. Mine tuck under there fine.
A good trouble free kit is brb.
They do set the motor forward a tad higher but work quite well. brb uses Hedman headers with that kit if I remember right.
Very nice complete trouble free kit that clears the factory steering box.
