Old 03-22-2012, 09:46 PM
John510's Avatar
John510 John510 is offline
Default Ridetech/Alston Car way too high?
I have a Fab9/Alston 4 link/Ridetech coilovers.
I have the shock mounts on the lowest bolts and I have my coil overs adjusted all the way down and the car still sits about 3" too high? Bolts are not snug so I know its not binding.
Do any of the other brackets on the 4 link adjust height or only pinion angle?
I need this baby lower!
[SIGPIC][/SIGPIC]
Old 03-22-2012, 09:51 PM
These things will help: windows, insulation, seats, trunk lid, bumpers, stereo, wiring, fuel tank, fuel, let the springs settle a little. When that's not enough there are quite a few threads around here on that very topic.
Old 03-23-2012, 08:04 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
You still have a bunch of weight to add to your car but read this thread. It is a pretty involved discusson of the Alston 4 link.
https://lateral-g.net/forums/showthread.php4?t=33473
It will answer a lot of your G-Link questions.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-23-2012, 08:48 PM
frojoe's Avatar
frojoe frojoe is offline
1) Support car by framerails
2) unbolt rear coilovers
3) raise rear end until you achieve the shock-manufacturer-recommended 13.25"-13.5" eye-to-eye measurement between upper mounting hole and lowest setting of lower hole
4) retake picture
Then we will re-visit this issue.
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 03-24-2012, 05:27 PM
Vince@Meanstreets's Avatar
Yeah, wait till you get the car together. The ride height will settle down as you drive it with all the weight on it. Don't judge it with an empty car.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 03-24-2012, 06:21 PM
John510's Avatar
I was told today that the Hyperco springs do not settle. They are made to stay the way they are for a really long time.
Im just going to see if Ridetech will trade my coil overs for some shorter ones.
[SIGPIC][/SIGPIC]
Old 03-24-2012, 07:30 PM
dhutton dhutton is offline
You have next to no weight on those springs. They will compress once you get the car finished, which is different than settling. You should probably wait until the car is finished before you worry about ride height.
Don
Old 03-24-2012, 07:50 PM
SR71 SR71 is offline
every spring settles. some just settle more than others. my ridetech/hyperco's have settled about half an inch after about 500 miles.
69 ss/rs clone, hugger orange w/wht stripes, 406/ 6spd/12 bolt drivetrain, ridetech tripples, speedtech torque arm, sc&c arms....centerline champ 506's and 275/335 kdw's
98 trans-am...black ram air convertable....firehawk bilstein suspension.
Old 03-24-2012, 09:09 PM
The suspension will settle a bit not so much the spring weight change. But the point is the weight will increase as you install parts compressing the spring more.
Rule of thumb is you wait for the car to be assembled and let sit for a bit till you set final height. Just wait till you get it all together... it won't cost you anything but a little time.
Dealer for
NEVER FORGET -11
