Old 03-23-2012, 09:13 AM
hud697's Avatar
hud697 hud697 is offline
Default Paint gurus inside please
I've got a work truck that I want to paint, never painted a vehicle before and figured my beater would be a good practice piece. The truck has the factory paint on it now, do I need to spray it with primer or can I just knock the clear down and spray it? Going from blue to flat black if that matters
Overkill is an often underrated achievement.
1969 Camaro - work in progress
2011 Camaro 2SS/RS A6
Old 03-24-2012, 08:10 AM
elitecustombody's Avatar
Depending on the budget and the quality you 're after. It would be wise to buy a quart kit of catalyzed black sealer before the paint. It will make it much easier to get better coverage and ease of application of color
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 03-24-2012, 08:23 AM
Rick D's Avatar
Rick D Rick D is offline
^^^^What he said plus you won't have to refine your sand scratch as much go with a wet on wet sealer. You can finish it in a 320 to 400 grit scratch and then seal and paint. Also when you sand the oe finish I'm sure you will have some areas that you sand through the paint to the oe sealer or metal. If you seal you won't have to worry about those areas.
Rick
Old 04-09-2012, 09:52 PM
67goatman455 67goatman455 is offline
you say its a "beater"? how bad is the paint on it now? it may need more than just sealer
Old 04-10-2012, 08:33 AM
hud697's Avatar
The paint is actually in good shape. Only reason I'm painting it is because I put some black wheels on it and blacked out the windows, headlights, taillights, and parking lights. Everything else is black, figured it was fitting
