Old 03-29-2012, 06:57 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Default Dry sump tank in trunk?
High Guy's, I am thinking of putting my dry sump tank in the trunk of my 69.
I am looking fo the pro's and con's
Greg
Old 03-29-2012, 07:43 PM
Rhino Rhino is offline
I've not done it in a car but I've had the tank behind the cab of a truck. The additional oil volume can help keep temps down if needed.
On the downside, it could prove to be the source of a mess during oil changes or you run into issues.
Old 03-29-2012, 07:59 PM
Thanks, Is there any pressure loss from the longer piping?
It would penetrate the trunk floor so, an oil change wouldn't be a problem.
Greg
Old 03-29-2012, 08:12 PM
We didn't witness any, but you need to insure your hose is sized appropriately.
The oil pressure is created by one (or more) of your oil pump stages. The rest pull a vacuum on the motor and return the oil to the tank. All that being said, the tank itself isn't under much pressure.
Edit: Full disclosure, this was in a 4x4 modified pulling truck, not a street car, so I can't answer to how corners may effect this setup.
Old 03-29-2012, 09:35 PM
Motorcitydak Motorcitydak is offline
The line(s) going from the bottom of the tank to the oil pump will be under suction. Make sure that the hose you use for that cannot be collapsed. I would not suggest using a regular rubber hose for that. Maybe braided or something similar
Old 03-29-2012, 09:45 PM
chr2002ca's Avatar
The Corvette Racing team puts their sump tanks in the back of their cars so it seems like something that has more pro's than con's if you do it right. I placed my 3qt Accusump in the back of my ride and noticed very little pressure drop. Not quite the same of course, but some of the same principles.
Chris Robinson
Old 05-12-2012, 06:51 PM
FETorino's Avatar
FETorino FETorino is offline
I'm surprised that nobody else here has put a dry sump in the trunk. I've been thinking a lot about where I want to mount my tank. I keep coming back to the thought of weight bias and the effect of moving a couple of gallons of fluid 6 to 8 ft to the rear.
Why not
Rob in SoCal
Old 05-12-2012, 06:56 PM
badmatt's Avatar
badmatt badmatt is offline
Im doing my tank in the bed of my truck,
1" ID SS tube under the cab single feed and dual return. 5 gallon petersons tank.
roughly 6ft of line both ways in total. the circle track guys do this all the time and have no issues.
Matt
Old 05-12-2012, 09:57 PM
FETorino's Avatar
Matt
That's what I was thinking.
Rob in SoCal
Old 05-12-2012, 10:19 PM
Ron in SoCal's Avatar
Greg - I was so big on this a few weeks ago. Spoke to Jason @ Katech, Gary @ ARE and Bill @ Aviad. I also posted a thread on 'Tech and got some good opinions. My situation was maybe a bit different as I already had a ported LS9 pump, Peterson tank and baffled pan. None of which I was relishing swapping out. BTW, (FET) Mike Maier is running a tank in the trunk and Brian H was very helpful in showing me the set up.
General concensus with the experts was it could be done w the factory pump and tank, but would probably need -16 feed/return. ARE suggested I use their pan...
Here's what killed it for me. First, I can't reconcile how a -16 return gets fully utilized when my thermostat, cooler and other parts use -12 and smaller? I kinda thought that must defeat the purpose, or at least create a fluid bottle neck. Second, have you priced -16 XRP fittings? One bulkhead pass through needed four, maybe eight ($800). I didn't price it out completely, but I figured I had $1200 or more in fittings for those two lines. Third, packaging it on my car was another fab item to add to the list. Take my word for it, we eyeballed it front to back and there's trunk work, pass throughs to ensure the lines are not the lowest thing on the car, and possibly subframe mods to get it to the pan. That's getting old w a painted/powdercoated car, and I've still got a long list to complete; I want to get my car on the road at this point so it was a question of priorities. Fourth, thank Hollywood for this, even w a firewall you're putting flammable fluids in the passenger compartment of a car that will see street time. Carl and I both agree (you guys may not) that even though there would be a firewall separation, the trunk is part of the passenger compartment. Fifth, everyone I spoke said there was no significant front end penalty with tank up there. Lastly, I'm not building a max effort race car. My car is a street car that will be track capable. It may see more track time than street time, but it would certainly be a different animal if it was track only. I don't know how to better explain this, but putting the tank in the trunk would violate the theme of the car. I could go further on this point but this is already the longest post in Lat G history...
Ron in SoCal
69 Camaro in progress
