Old 03-31-2012, 06:44 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Default Can axle tubes be replaced in a 12bolt?
I have an old 12bolt rear end in the shed but the axle tubes are junk. Can these tubes be replaced? Who does that kind of work?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-31-2012, 09:37 PM
coolwelder62's Avatar
check W/Moser engineering.
Old 04-01-2012, 12:14 AM
intocarss's Avatar
found this
http://www.chevelles.com/forums/showthread.php?t=251058
Old 04-01-2012, 11:44 AM
badmatt's Avatar
badmatt badmatt is offline
If you are doing upgrades to it like new brakes and axles go to a ford 9" housing end..
Old 04-01-2012, 12:22 PM
Chev67 Chev67 is offline
Yes. I had a busted tube and had it replaced.
Old 04-03-2012, 09:50 PM
The WidowMaker's Avatar
not sure where youre at, but currie will do it.
"The WidowMaker"
