Closed Thread
Old 04-01-2012, 06:09 AM
Bowtiguy Bowtiguy is offline
Default FS: 2008 JSB Z06 570rwhp/532rwtrq forged motor 20K miles, $48.5K in mods ZR1 Wheels
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<SOLD>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Whats Up for sale? My 650hp 2008 Jet stream Blue Z06 corvette. Purchased new in March 2008 from Kerbeck Chevrolet in NJ. Delivered enclosed by Reliable Transport. 3M clear guard installed the next day on over 1/2 the car! One owner car. No accidents. Registered /plated in Colorado. My goal was to build the fastest lapping day car I could and still be able to drive to work 2-3 times/week in comfort (weather permitting). I also wanted to be able to drive to the track for lapping days without the need for a tow vehicle/trailer. I accomplished that with a street friendly 570RWHP/532 RWTRQ , 28 MPH highway with all the creature comforts still in place including an Alpine/Dynaudio stereo system, heat, A/C and onstar. Guaranteed to be the quietest C6Z you have ever driven with the Dynamat/insulation.
Price: My goals/priorities have changed in the last year or so and I find myself enjoying the car less on track days ( a total of 5 hrs in the past two years). On top of the $72K purchase price, I have invested over $48.5K IN PARTS/Labor modifying this car as currently listed and I have a large folder of receipts to document this for any potential buyer.
Shipping:Shipping will be the responsibility of the buyer. I will make myself available for pick-up if you are having the car shipped. I have no means to deliver myself, unless you choose to purchase the car without all the race gear, then you could fly into Denver and I’ll pick you up!
Payment/Fineprint: I have tried to described everything as accurately as possible. I encourage any potential buyer to send me a PM or E-mail at [email protected] I'll give you my cell number and we can go from there. Vehicle is available for local inspection/drive for serious buyers (weather permitting).
I will take $1000 deposit upon purchase and the remaining payment within 14 days. Paypal is acceptable for deposit. Bank transfer is preferred for final payment. Bank check will work, but the car will not leave until funds have cleared. Car will be released upon full payment and the title upon the funds clearing.
Trades...
If the car does not sell by summer time, I may be interested in a trade/cash for a good quality complete 1958,1959 or 1960 vette. Numbers matching not required.
Old 04-01-2012, 06:14 AM
Default Complete list of mods.....
Modification list
Intake......$2580 in upgrades
•Lingenfelter CAI ( Cold air intake) assembly
•Lingenfelter 100mm MAF ( mass air flow) sensor
•LS7 TB ported by LS2 portworks
•F.A.S.T. 102mm Intake ( painted to match GM ZR1 wheels)
•F.A.S.T. Billet fuel rails and Earls –AN plumbing
Heads...$5617 in upgrades
•GM LS7 castings port & polished by LPE including hand smoothing, new valve seals ( 2K miles since refresh)
•Stock titanium intake valves
•Delwest titanium exhaust valves
•PVD coating on all 16 valves for additional wear protection
•Ferra dual spring package from LPE
•Harland Sharp Version 2 LS7 rockers
•Katech LS7 Valve covers ( vented to dry sump tank and painted to match ZR1 wheels)
•Katech LS7 Coil Relocation kit/plug wires
•custom valve cover inserts by Austin Barnet designs
•NGK TR6 irridium plugs
Valve trane ( all installed 7/11…2K miles of use)...$1409 in upgrades
•Comp Cams Camshaft from 21st century muscle cars/LPE
oGrind # 3730R/3734R HR114.0
oPart# 54-00011
o240/248 .643/.651 lift at 114 LSA
•Comp Cams Magnum pushrods
•Katech C5R timing chain
•Morel HIGH RPM link bar lifters
Short Block (12K miles)...$7698 in upgrades
•New LS7 block fall 2009.
•Callies Magnum 4.0” Forged crankshaft
•Katech rebushed GM titanium connecting rods/ARP bolts
•Katech Tensioner
•Diamond Racing Forged pistons ( to fit .927 pin and stock Titanium rods)
•ATi Super Damper
•Fasteners…everything ARP makes for the LS7 including head studs.
Oiling system (same specs as Katech stage II but w/ larger oil capacity)...$3578 in upgrades
•A.R.E. ( Armstrong Race Engineering) stage III dry sump pan ( upgradeable to stage III 2nd scavenge stage)
•Custom Peterson Fluid systems dry sump tank/breather ( 2.5 gallon capacity)
•Katech modified (BLUE) LS7 oil pump
•12AN feed lines
•A.R.E. oil filter relocation kit
Exhaust ...$4432 in upgrades
•Kooks 1 and 7/8 to 2" stepped race headers ( jet hot coated)
•Kooks Off-road pipe ( jet hot coated)
•Kooks Cat pipe for off season use
•B&B fusion exhaust system
•Mild to Wild switch mounted to dead pedal
•Elite thermal abs tunel plate
•AEM Wideband O2 monitoring for tuning ( display mounted in glove box)
Cooling ...$1350 in upgrades
•Ron Davis Radiator ( new spring 2010)
•Integrated tranny cooler (factory oil cooler)
•Pfadt silicone hoses/clamps
•Low/Hi/stock fan switch mounted in cigarette lighter position ( no cutting)
Clutch ...$2850 in performance upgrades
•RPS BC2 billet carbon twin disc with steel flywheel ( new slave, TOB) 5K miles of use since installed.
•Castrol SRF synthetic fluid
•Remote clutch Bleed line
Brakes...$710 in upgrades
• OEM Z06 drilled calipers front/rear
• OEM Z06 drilled rotors front/rear
• OEM Z06 padlets front/rear
• Earls Stainless steel brake lines
• Castrol SRF brake fluid
• LG motorsports spindle duct system
Suspension...$4393 in upgrades
• Pfadt Racing camber kit
• LG motorsports ( Penske shock/hypercoil springs) G2 coilovers
• SKF (ZR1) racing hubs
• ARP wheel studs
• Factory sway bars/bushings
Exterior Modifications ...$8093 in upgrades
•GM ZR1 19” front 20” rear painted silver wheels ..NO REPRODUCTIONS!!!
•Michelin PS2 run-flat ZR1 spec tires ( 2,000 miles since mounted on NEW ZR1 factory wheels)
•2008 GM TPMS (tire pressure monitoring sensors)
•GM ZR1 Facia reinforcement
•Stainless steel body panel mounting hardware
•Upgraded high beam bulbs
•Upgraded Low beam HID bulbs
•HID foglite assemblies to match Low beam color/intensity
•Apsis front fender splash guards ( removable)
•3M clear bra mounted on front facia/hood AND lower half of the car (below the body line) from the front to the rear.
•window tint all three windows
Safety...$1340 in upgrades
•Pfadt Racing 4 point Chassis bar/ Harnes bar
•Phoenix Racing Rear tow hook - fixed
•Phoenix Racing front tow hook - removable
Audio System..$2500 in upgrades
•JVC AVX-810 full screen touch head unit ( XM ready, SD card ready, many features..looks stock!)
•Metra wiring adaptors ( NO CUTTING, factory system can be reinstalled with no sign of aftermarket installation)
•Alpine PDX 4.100 amplifier
•Dynaudio 9” door woofers/mids ( uses factory speaker mount holes)
•Dynaudio Door 1” tweets ( uses factory speaker mount holes)
•Dynaudio passive crossover system
•Boxology Sub enclosure for C6 corvettes ( fits drivers side rear well.)
•Aura 10” aluminum cone subwoofer
•Dynamat Installed on all floor boards
•“Crazy Cowboy” heat insulation under factory carpet.
VIDEOS---------------------------------------------------------------------------------------------
Engine start-up and idle with NPP B&B fusion exhaust cycled on/off. My new camera has a VERY sensitive mic on it so the car sounds louder than it really is but this video gives you an overall idea of how easily the cars starts and idles. Car is currently tuned for the least amount of stop light odor w/o cats.
https://www.youtube.com/watch?v=DQ4zD...a9AUAAAAAAADAA
Exterior walk around
https://www.youtube.com/watch?v=qMdLR...3&feature=plcp
Engine bay walk around
https://www.youtube.com/watch?v=tnqiu...2&feature=plcp
Interior walk around
https://www.youtube.com/watch?v=FkZDS...1&feature=plcp
Old 04-01-2012, 06:26 AM
Default Gear head shots and vehicle condition.
Why am I selling? I’ve been asked that many times lately. Ultimately, The car is WAY too nice to cage and race in T3/T4 NASA or wheel to wheel events which is my next driving goal. Since I do not need a 650hp daily driver, I’ve decided to sell the car now and build a completely caged dedicated track car ( with less power to fit class requirements) a year or two from now. The future owner could literally pull off the 3M clear guard from the car (complete front end and lower ½ of the car since it was new) and the paint would be 98% perfect at 20,504 miles.
Condition: Overall, this car is in great to excellent condition. 3K of the mileage came from a trip to the Road America back in fall of 2008 to participate in the NCM track event held there. It was the first test of the car and it had no problem handling the ZR1 prototypes while still running its original tires!
Interior: The interior is immaculate. Since the stocks seats are out of the car most of the year in favor of the Sparcos, the seats show very little wear. Car has never seen smoke, food, pets or otherwise. Always is run with weathertech full coverage mats. There are a few small surface marks on the door handles if you look closely ( I should have bought the wife a smaller ring)
Wheels/Tires: 96% perfect. These are hard to find GM factory painted ZR1 19/20" Speedlines. They have 2K miles on them since being installed earlier this year. They will clear ANY brake package available for the C6Z. The tires are ZR1 spec Michelin PS2 run-flats with 2008 TPMS’s
Paint: 98%. Car literally has 3 small (BB sized) chips. I know because I do all the detailing myself (Mequires/Zymol products, disposable microfiber towels, no BUFFERS!). Mostly Power washed and ALWAYS power washed before hand washing ( double bucket method). Clay bar use before every waxing. This car has VERY VERY few of the minor clear coat “spider webbs” most cars get.
Glass: side and rear windows are tinted and are 100% perfect. If this car a fault at all, its the windshield. It is a solid 85% with the normal pitting seen early in the AM hours with the sun in your face. Tint is easily removable but is not too dark. A new windshield would make this car look new from the outside, I will leave that up to the new owner.
Motor/driveline: Excellent! Top end was freshened in July of 2011 and only has 2K miles of use. Transmission and rear differential are running Royal Purple synthetics installed fall 2010. New Coolant installed 7/11. Mobile-1 Oil just changed 11/11.
Old 04-01-2012, 10:48 AM
cencalc6 cencalc6 is offline
By Far 1 of the Nicest,Well put together Z06....If I was in the Market for another vette we both will be in contact... for a Awsome Seller
Old 04-01-2012, 11:17 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Wow! If I had an extra 60K..... that is one nice Z! GLWS
Old 04-01-2012, 04:34 PM
intocarss's Avatar
Cannot get your videos to work
Old 04-01-2012, 08:13 PM
John510's Avatar
John510 John510 is offline
Mind if I ask which headers those are in the pic of the valve train?
[SIGPIC][/SIGPIC]
Old 04-02-2012, 12:14 AM
killer67's Avatar
killer67 killer67 is offline
Does it have HUD? Who did the install and engine work on the car - was it LPE?
Old 04-02-2012, 12:20 AM
He's running Kooks Headers
Old 04-02-2012, 12:26 AM
Just a little help to answer a few questions.....Yes it does have Heads Up Display.....LPE stands for Lingenfelter Performance Engineering... Most likey he had LPE perform all his Engine work and Install.
Closed Thread
