Old 04-01-2012, 08:22 AM
ProTouring442's Avatar
Default Bearing adapter needed...
I am looking for someone who can machine a couple of rings enabling me to install a press in roller bearing with an outside diameter of 40mm into the hub of a motorcycle wheel which uses a roller bearing with an outside diameter of 42mm.
Shiny Side Up!
Bill
Old 04-01-2012, 01:02 PM
I found this place: http://www.emachineshop.com
Any idea what the actual dimensions should be? I was thinking they should be exactly 40mm ID and 42mm OD and the undersize on the hole in the wheel will take care of the press fit.
Shiny Side Up!
Bill
Old 04-01-2012, 06:41 PM
Well, more research has paid off... found a bearing and adapter i can use.
Shiny Side Up!
Bill
