Old 04-02-2012, 09:50 PM
COYBILT's Avatar
COYBILT COYBILT is offline
Default 1971 camaro TH350 linkage/ cable bracket question
Hey all, I have a question regarding a 1971 camaro floor shifter cable bracket.
I need to see if any one has any under car shots I can use for reference. I am putting together a humpty dumpty camaro, its missing a lot of parts and I am using various years of camaro parts to complete the trans to column indicator linkage. The shifter cable bracket is off a 1975 camaro and seems to look correct but i am not sure. if anyone has pics of the under side of there console shift 1971 or 72 camaro i would appreciate it. I also need to know if anyone knows where to get the grommet that go's into the frame for the cross bar that connects the sub frame to the trans linkage.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 04-06-2012, 11:30 PM
Vince@Meanstreets's Avatar
Default camaro reference and parts
Check with Steve's Camaro's in San Bruno. He will have everything you need.
http://www.stevescamaroparts.com/
I just noticed your in Livermore...try Matts Classic bowties in Dublin. http://www.mattsclassicbowties.com/
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
