Old 04-03-2012, 05:22 PM
ricer ricer is offline
Default Ridetech spindle instal
so i finally got around to installing the spindles and i can spin the castle nut to just barely finger tight while not being so low on the ball joint that the cotter pin won't be within the nut.
Has anyone ever had to add washers/shims/etc to the ball joint to be able to get the appropriate torque on the castle nut while still being able to have the cotter pin nested inside the nut? I am thinking 1-2 possibly 3 flat washers should do the trick but just wanted outside opinions as well.
565 twin 80mm 67 Firebird
545ci FFR MKIII Roadster
Old 04-03-2012, 06:15 PM
coolwelder62's Avatar
Give Darren Schilling @ Ride Tech a quick call tomorrow.He is my Go to guy @ Ride Tech.
Old 04-04-2012, 04:21 AM
Supporting Vendor
You can add washers between the spindle and the nut to provide the required distance to make the cotter pin line up with the castle nut.
Skunk Werks
Ridetech
www.ridetech.com
Old 04-04-2012, 06:12 AM
THanks, that's what i thought and was going to do but just wanted an outside opinion.
