Old 04-08-2012, 08:16 AM
markss28 markss28 is offline
Default How many coats of clear?
I'm having my 73 camaro painted again. I had it painted in 04 but they only put about 2 coats of clear. When they sanded it was about one coat and not so shiny. A year later I had another guy lay on 3 coats of clear and wet sand. It had by far more shine and depth but he didn't spend enough time sanding. Either way at the time I was much happier with the finish then before.
Now it's back in the booth. What is the best way to lay the clear, how many coats, and how much sanding to get a straight and deep look?
Never Stay Stock
Old 04-08-2012, 11:47 AM
elitecustombody's Avatar
Are you or the shop is doing the work?It takes skills and right tools to make finish slick and straight and it has alot to do with what's under that paint. For a nice wet slick look you need at the minimum 4 coats of high-solids clear that has 2:1 mixing ratio or 6 coats of watered down clear with 4:1 ratio. After application you must let it sit for a month or so to let all solvents out ,so it won't die back after sanding and buffing.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 04-08-2012, 06:33 PM
Thank you so much for replying. I've done about 100% of the work on the car with the exception of the paint and body. I wouldnt know where to begin. I have it at a body shop but I want to make sure that they are doing it right.
Never Stay Stock
Old 04-08-2012, 07:20 PM
Rick D's Avatar
Rick D Rick D is offline
You want to watch how many coats of clear you put on at one time, all clears are not the same. Go with what the company that makes the clear recommends. We have a clear that if you put on more than 2 coats with out curing it first the first coats WON'T cure and it will cause issues down the road. Just make sure when applying more then 2 coats at a time the paint company recommends it. Most of our clear coat are max 3 coats during one application. If more is wanted or need you can sand it down and then reclear.
Rick
Old 04-08-2012, 08:36 PM
right now there is 3 coats that were put on 3 days ago. They said they were going to start sanding tomorrow. I think they are going to lay another 2 coats and then sand and buff again.
Never Stay Stock
Old 04-08-2012, 09:15 PM
I'd say let the shop do what they are paid to do.Nobody likes a customer that tries to tell the shop how it should be done. With that being said,I'm assuming the shop explained the process and what materials they will be using.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 04-08-2012, 10:02 PM
I agree, and would love to sit back and watch the magic happen but the owner of the shop told me he already put down 2 gallons of clear but the painter says he's only sprayed 3 coats. Just want to make sure I'm not getting hosed.
Never Stay Stock
Old 04-09-2012, 07:45 AM
Between the shop owner and painter someone is not telling the truth.I'd try to get a better answer. What type and brand of clear are they using?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 04-09-2012, 08:15 AM
A lot of the flat slick look you're looking for might have more to do with the way it's blocked AFTER the clear is laid on... some start with too fine of grit and end up getting the "lake effect" -- because the fine won't block it hard enough to really get it flat. You end up with no orange peel but end up with "the lake effect".
Old 04-09-2012, 11:25 AM
Make sense. I saw a friends chevelle they wet sanded with 1000 and it looked great until u looked down the lines. They sprayed it again and I think they used 600 or 800 first and worked their way up. Took him about 1.5 days but it was awesome.
Never Stay Stock
