Old 04-17-2012, 07:53 PM
makoshark makoshark is offline
Default 12 bolt rebuild
I recently ordered a new ring and pinion, carbon fiber clutches and new springs for my Eaton posi 12 bolt rear end. I had already bought new Moser axles some time ago. I decided to buy new c-clips for the axles. When I received the new c-clips, I noticed they were copper. Are these sufficient enough for a performance oriented 67 Camaro?
Old 04-19-2012, 07:06 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Are you sure they are copper? I suspect they are gold colored hardend steel. Test them with a magnet. You really should consider a C-Clip Eliminator kit.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 04-20-2012, 07:45 PM
I have since found out they are not copper. I did not think of using the magnet test. Thanks for the tip
