Old 04-26-2012, 10:00 AM
PhillySpeedNYC PhillySpeedNYC is offline
Default Need some advice on my Power Rack and Pinion set up, need less assist more feedback
My Mach 1 has a power Rack and Pinion, a Randals Rack I am not familiar with this system or its design versus others on the market for these cars.
I absolutely love driving my car but my NYC roads suck and with the over assist its so hard to control the car when going fast. I want to knock the assist down a bit.
Anyone have suggestions?
Old 04-26-2012, 10:38 AM
Ron in SoCal's Avatar
Make sure your PS pump output is flow matched to the rack requirement. You can get a valve from Turn One and they probably can ID your rack for you. There was a recent thread on just this subject, but I'm too lazy to look...
Ron in SoCal
69 Camaro in progress
Old 04-26-2012, 01:04 PM
ironworks's Avatar
Borgeson - 899001 - 15 dollar fix. Easy money.
Old 04-26-2012, 06:18 PM
Rhino Rhino is offline
Your rack could need a stiffer t bar. Have you called randals to see what your options are?
Old 04-27-2012, 04:50 AM
I spoke in detail to the Randals Rack guy and he said the PS pump is a low pressure pump, GM style. He is certain the issues have to do with alignment being way out of spec. I did have the car aligned last week but they never gave me a print out and i only know the cars front end feels worse.
i found a shop that i can wait and watch what they are doing. I am installing a new steering wheel tonight so it makes sense to do that just in case it comes off center prior to a new alignment.
if the alignment doesn't work i might just disable the power pump and run it manual.
What is a T Bar? Photos?
Old 04-29-2012, 08:30 AM
Originally Posted by PhillySpeedNYC View Post
...He is certain the issues have to do with alignment being way out of spec...
I'd be interested to see hear why he came to this conclusion. Power steering feel is very subjective. Some people want a ton of assist, others want very little. You may fall on the "heavy" end of the spectrum.
The one thing I could agree with in regards to the alignment is how it was performed. Did Randal's supply the alignment specs or did they align it as a stock mustang? The reason I ask is that modern vehicles/steering gear uses much more caster than you would have found in the stock mustang. This helps reduce how "twitchy" a car can feel on the road and will help with "return to center".
In regards to the T-bar: The torsion bar is internal to the rack. It's a little difficult to explain but the twisting of this bar is what controls the power assist you will get from the rack. If you want less power assistance you'll want this bar to twist less.
Torsion bar selection is something that happens at the factory or during rebuild. I didn't know if Randals had any different options to tailor the rack to your liking.
EDIT: This link from Woodward does an excellent job explaining what the torsion bar's job is. Much better than I ever could.
http://www.woodwardsteering.com/inde...:woodward-tech
Old 05-08-2012, 10:15 PM
funcars funcars is offline
I have a power rack and pinion in my Mustang and have some extra caster (6.5 deg) and a good alignment with 275-40 17s and a bit of scrub radius. Even with that it used to have a very overboosted feel as well. I changed the T-bar since it has a woodward servo valve. It made a significant difference (improvement). Woodward was very helpful in helping me pick the bar to use.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
