Old 04-26-2012, 09:32 PM
John510's Avatar
John510 John510 is offline
Default Speedtech frame mount help
My engine sits about 2-3inchs too far forward. So as I was searching for setback mounts I found that I have my energy mounts upside down. Would this cause the engine to sit really far forward? Heres a pic of what Im talking about. The engine also sits too high and needs to come down about 1/4 inch or so.
[SIGPIC][/SIGPIC]
Old 04-26-2012, 09:40 PM
camcojb camcojb is offline
Upside down affects height a bit (upside down is lower). It does not affect front to back though.
Old 04-26-2012, 09:44 PM
John510's Avatar
So if the engine is too high now then turning them the right way would make it go even higher? Well actually its the tranny that is too high not the motor.
Just making sure before I pull the engine again. Thanks for the help Jody
[SIGPIC][/SIGPIC]
Old 04-26-2012, 09:57 PM
yes, upside down lowers the engine slightly, so you won't want to flip them in your case. You are very welcome.
Old 04-28-2012, 05:35 AM
MaxHarvard's Avatar
What plates did you use?
Also the frame mounts have about an inch adjustability backwards too.
Mines sits 1/2" off the frame with the ATS mounts and poly bushings.
Btw your pic is kinda hard to see.
Old 12-09-2012, 01:21 PM
rons69camaro rons69camaro is offline
Default Same problem
Were you able to get the motor to sit closer to the firewall? I'm having the same problem. My LS1 is sitting about 3.5 inches away from the firewall. I'm using the Speedtech subframe with the Speedtech mounts from AutoKraft. Does anyone have any advice on how to get the engine closer to the firewall?
Old 12-09-2012, 01:46 PM
cencalc6 cencalc6 is offline
adjustable Brackets will fix your problem....I was also running Autokraft brackets...Google Adjustable LS Engine mounts or Ebay
Old 12-09-2012, 02:18 PM
Any chance anyone would have any advice on which ones work best? Dirty dingo has a couple of options.
Old 12-09-2012, 03:00 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have used the dirty dingo DD 3 position mounts on a few LS swaps. One set is in my wayne due subframe w/ stock fbody oil pan. I used the "back" position. Its close to the firewall. The Last 2 LS swaps we used same DD motor plates on stock subframes. I think we used the nuetral or middle location. What does speedtech recommend for motor plates? I can't tell where/why your motor is too far forward from that pic. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 12-18-2012, 04:46 PM
John510's Avatar
I ended up not moving it back. If you move it back farther you need to clearance out the trans tunnel. Since my car was already painted I left the Energy mounts in there.
[SIGPIC][/SIGPIC]
