Old 05-06-2012, 03:53 PM
latoracing's Avatar
latoracing latoracing is offline
Default Custom Built Stainless Headers
Has anyone tried to build your own headers? I have started with headers that "fit" and ended up re-fitting them, but never started with a pile of bends, and actually constructed them. I have ordered bends and other parts from Stainless Headers before, and love their products. My new build will be a trial run for alot of new to me builds. I have a purge system set up in orer to fill all the tubes with Argon while they are being welded, this makes the inside nice as well. I am wanting to build a 4 into 2 into 1 system to help with ground clearance, and tourque production.
I think this will be fun, and alot of work.
What do you think...
Old 06-17-2012, 05:07 PM
Injected65's Avatar
Injected65 Injected65 is offline
I just built my first set for my buddies car. The actual fabrication of the headers was easier than I expected, but the welding on the SS kicked my butt more than I figured it would. The welds turned out decent, but they weren't quite as picture perfect as I had hoped.
Here is one pic when they were first tacked up.
Old 06-18-2012, 09:48 AM
Yep build them all the time it is alot of work, but the end result is worth it! If your going to do them often I suggest getting a set of blocks from these guys - http://www.icengineworks.com/icew1750.htm Save a ton of time!
Jeff Allen
J2 Speed and Custom
Old 06-18-2012, 01:12 PM
rallystyle rallystyle is offline
check this out
http://www.stainlessheaders.com/headerfabrication
