Old 05-07-2012, 09:40 PM
COYBILT's Avatar
COYBILT COYBILT is offline
Default LS2 Drive by wire pedal bracket
Hey all,
It been a while since i have posted, I need the help of all Drive by Wire owners. I would like to know if the aftermarket has come out with a bracket that mounts a factory GM drive by wire pedal (06 GTO Pedal) in the first gen F-bodys. If I could buy a pre made mounting bracket, it makes far more sense. I dont want to burn up time fabing one up. I Just thought I would ask the folks of lateral-g or we shall say Firstgen-g.net
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 05-07-2012, 09:48 PM
Ron in SoCal's Avatar
Just did this - nothing perfect yet. Roger has a bracket that may help and John Parson's also has mounting bosses that I think may work as well.
Ron in SoCal
69 Camaro in progress
Old 05-08-2012, 07:35 AM
dj3 dj3 is offline
When I bought a new corvette DBW pedal it came mounted to a metal backing plate that was easily adapted to the firewall. The top left hole actually lined up with the steering column hole and I just welded on a couple of legs soo i could remove it if needed.
Derek
Old 05-08-2012, 09:52 AM
ironworks's Avatar
We have one in stock that should give you a good start to fit into your car. it is designed to run the 10379038 part number gas pedal.
Its on my website
Old 11-14-2015, 05:38 PM
cpd004's Avatar
cpd004 cpd004 is offline
The Ironworks seems like it mounts very high up. Also looking for something but for a 2nd gen.
1971 Firebird
2017 SS
Old 11-14-2015, 08:18 PM
ironworks's Avatar
The bracket is designed a solid base line. Guy cut it to adjust height and pedal height is variable from person to person. The bracket is designed to be trimmed but fits in almost any GM model. Never had any body complain or return one. Sold a bunch of them over the years.
Old 11-14-2015, 11:03 PM
im4u2nvss im4u2nvss is offline
http://www.detroitspeed.com/1967-196...l-bracket.html
This is the one I have. It is for a C6 pedal, not sure how they compare to a GTO but it may work for you.
Old 08-08-2016, 11:40 PM
Bmf5150 Bmf5150 is offline
Which bracket is the best??ironworks or Detroit speed
Old 08-12-2016, 01:44 AM
68LS1's Avatar
68LS1 68LS1 is offline
Scarebird
https://scarebird.com/index.php?rout...product_id=163
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
