Old 05-11-2012, 11:13 AM
inkman101 inkman101 is offline
Default 305/40/18 on a 9.5 wheel ?
Hi, anyone running a 305/40/18 on a 9.5 wheel?
Thanks Pete
Old 05-11-2012, 11:17 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
That seems a too wide for a 9.5" tire. I'm pretty sure the tire specs on a 305doesn't warrant a 9.5" tire. If you mount it, there would be alot of tire going inward, so to speak, from the rim not being wide enough. I'm no expert though. Just my $.02. I previously had 305's on an 11" rim. Not to mention a 40 sidewall for a 305 is pretty tall.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-11-2012, 11:40 AM
Flash68's Avatar
Flash68 Flash68 is offline
Nitto's size chart recommends at least a 10.5 wide.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-11-2012, 07:42 PM
Nitto says 10 to 12, will a 1/2 make a big deal? They are exactly what I want as far has size goes 27.75 high. I'm looking at Centerline rims and they only go up to 9.5.
Pete
Old 05-11-2012, 07:51 PM
Track Junky's Avatar
A 9.5" wide wheel isn't 9.5 wide. Measured width is what tire manufacturers go by. My guess is a 9.5" wheel is around 10 1/4" measured width. Recheck fitment specifications for specified tire and then measure from inside of lip to inside of lip on wheel.
Gaetano Cosentino
Old 05-11-2012, 08:48 PM
It will probably work but I wouldn't go outside a tire manufacturers recommendation. That could bite you at the wrong time.
Old 05-11-2012, 09:18 PM
With a low profile tire I think it is even more critical to stay within the range. There just isnt that much sidewall there to perform the transition.
I'm running into similar problem while shopping for wheels and tires too. Unless you can spring for a uber pimp forged wheel it is hard to find many at 10" width. Who wants to spend the time and money on a minitub and put a 285 tire in there on the 9.5" wheel. Vintage Wheel Works now has an 18X11 wheel out though. Problem then is tires. Seems limited in the 305/35 - 315/35 range for 18" wheels. Oh the joys of project cars
John
'71 Nova (Build thread)
FFR Roadster
Old 05-12-2012, 12:54 AM
Flash68's Avatar
Yeah they already give a 2" wide range of comfort. I would not venture outside that even a half inch.
2014 4 tap Keezer
Old 05-12-2012, 08:05 AM
Thanks, not what I wanted to hear, LOL but that was what my mind was thinking
Pete
Old 05-12-2012, 11:26 AM
Flash68's Avatar
Pete
I would add that if you are planning on doing any type of performance driving with this car (street or track) I would def stay within recommended spec.
But if you are just gonna cruise and put around at low speeds, and maybe don't care about uneven wear or a perfectly matched wheel/tire you likely would be fine I'd think.
2014 4 tap Keezer
