Old 05-16-2012, 04:23 PM
gardnerme gardnerme is offline
Default SBC 406 rotating assembly - $1300
I had been building a 406 small block, but I have come to the realization that this engine just isn't going to happen right now. As such, I need to put up for sale the rotating assembly as listed below. All prices are OBO. Email me with questions. Prefer local pickup in or around Acworth, GA.
Eagle crank - part # 440037505700. Never used, but I think my engine builder did some machine work to the rod journals (turned them down .010) because he wasn't satisfied with the factory tolerances. It also looks like he may have balanced the crank.
http://www.eaglerod.com/
Retails new for $570 per set. Asking $500.
Eagle 6.0 H-Beam rods - part # CRS6000B3D. New in box, but they have Sharpie marker numbers from where my engine builder had measured them to start balancing the rotating assembly.
Retail new for $350 per set. Asking $300.
SRP/JE flat top forged pistons - part # 138100 -- New in box, but they have Sharpie marker numbers from where my engine builder had measured them to start balancing the rotating assembly.
4.155 BORE, 400 SBC flat top -5c. Ideal for oval track to street/strip applications. Forged from 4032 low expansion high silicon aluminum alloy heat treated to SRP specifications. Forced Pin Oiler for increased wrist pin lubrication. Pin fitting, and double spiro locks included. 927-2750-150 wall wrist pin (130 grams) included. CNC Machined ring grooves accept 1/16, 1/16, 3/16 rings.
http://www.jepistons.com/Products/138100.aspx
Retail new for $525 per set. Asking $450.
JE Sportsman ring set -- part # S100SB-4155-5. New in box. The part number looks to have been replaced on the JE website with # J100SB-4155-5.
4.155 1/16 1/16 3/16 ring set
http://www.jepistons.com/Products/J100F8-4155-5.aspx
Retail new for $175 per set. Asking $150.
Will take $1300 for entire package.
Old 06-28-2012, 07:22 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Is this still for sale?
Thanks,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
