Old 05-22-2012, 11:38 AM
65malibuSS 65malibuSS is offline
Default Street Torque Converter Selection
Just want some opinions on Choosing a torque converter for a street car with a big cam .700 lift., th400(full manual valve body), 496cid, 11.1
just curious what the difference would be between say a 5000 and a 3000, how would it act? what would be better?
Not intelligent yet when it comes to transmissions.
Old 05-22-2012, 03:06 PM
camcojb camcojb is offline
A 5000 stall in my opinion is not really a street converter. I would go with the recommendation of whomever you're going to buy it from. To use this on the street requires somewhat of a compromise.You'll likely need something at least in the 3000 rpm range minimum, but it depends on your HP, torque curve, gears, weight, rpm range, tire size, etc. The good converters will give you the flash stall you need for launch but not be so slippy feeling cruising down the road. This is an area to not go by price alone; a bad converter will give poor performance on the track and street, and even though it's cheap you likely won't be happy with it, and your et's/mph will suffer.
You get too high on the stall and you probably won't like it a lot on the street; it will slip so much that it feels like a clutch car with a worn out clutch. You hit the throttle and the engines revs but the car doesn't move much. A real high stall will also bring in a lot more heat, though any converter will require a good cooler for the trans.
Old 05-22-2012, 03:07 PM
badmatt's Avatar
badmatt badmatt is offline
Call a converter company for the best set up for your car IE Protorque, Neal Chance, Coan.
id stick to 3K stall on the street, or go switch pitch! best of both worlds!
Matt
Old 05-23-2012, 07:49 AM
Cool, thanks guys
