Old 05-22-2012, 02:52 PM
Pasquale Pasquale is offline
Default 1200 hp 4L80E
Hey I want to run a 4L80E in a 1000hp 69 Camaro. The car will only be driven for fun on the street. Do you have any recommendations to transmission builders? What do you guys think of MadDog Transmissions and Monster Trans? Here are the links to each page of their 4L80E transmissions.
http://www.maddogtransmissions.com/4...lash-4l80e.htm
Monster Trans:
http://monstertrans.com/store/produc...mance-2WD.html
Old 05-22-2012, 03:02 PM
badmatt's Avatar
badmatt badmatt is offline
Jakes performance transmission, RPM transmission, FLT transmission, there are many more.
Matt
Old 05-22-2012, 03:05 PM
Matt
Thanks!
Do you know if the transmissions I found are worth my time?
Old 05-22-2012, 03:43 PM
Rossler built one for me. He has built transmissions for the fastest automatics in the world, and mine came with clutch packs that weren't even available on the market at the time. Its also built to handle full throttle shifts into overdrive on a supercharged 581 big block. I have never heard a bad word about Rossler.
Old 05-22-2012, 05:58 PM
RoadHammer RoadHammer is offline
Jake's builds a really good 80E. I have his top-of-the-line model for a 1000hp street/strip build.
Old 05-22-2012, 07:21 PM
CE69 CE69 is offline
Thinking about running the same transmission. Does anyone know if you have to modify the floor?
