Old 05-23-2012, 04:31 PM
phillym5 phillym5 is offline
Default where to buy best DIY carbon fiber overlay kit?
I want to try and do a few things on the camaro with CF overlay. Any suggestions on where i can get a kit from?
thanks.
Old 05-23-2012, 04:57 PM
djorgensen3 djorgensen3 is offline
Default Water transfer/Film dipping
Try here.
http://www.mydipkit.com/
Old 05-23-2012, 06:01 PM
Thanks!!
Old 05-23-2012, 06:38 PM
ALLSPEED01's Avatar
ALLSPEED01 ALLSPEED01 is offline
Look at 3M carbon fiber Di-Noc. Type that into google it will pop right up. Its a cool vinyl that is really thick and you just form it with a heat gun. There is a ton of videos on how it works.
Old 05-24-2012, 12:35 AM
MattO MattO is offline
I've ordered and used stuff form cfwrap.com
No service to speak of, but the products are solid.
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
Old 05-24-2012, 07:26 AM
thanks.
Are you looking for a self-stick application like a film or printing as suggested above - or was the question overlaying real carbon onto your parts ?
No real 'kits' out there - but you can easily use 2 x 2 carbon twill and some clear laminating resin to cover anything.
Properly abrade and clean the surface - laminate the carbon - after it cures - finish sand and spray on a few coats of clear.
Here’s a place in Indy where I buy as a sample for ya. You can check prices and see if it fits what you planned to spend.
www.avtcomposites.com
Good luck !
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
