Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 06-08-2012, 09:31 AM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default New! FAST TRACK Subframe for 2nd Gen Camaro/Firebird
We are pleased to announce the introduction of our 2nd Gen Camaro/Firebird Subframe.
Standard Features Include:
RS Fast Track front suspension utilizing proprietary suspension geometry
C6 Corvette spindle and Z06 hub assembly
Afco single adjustable Pro-Touring coilovers
1.25" splined front sway bar with C6 Corvette end links
Quick ratio power rack & pinion steering
Complete bolt in front subframe
1-5/8" and 1-1/4" diameter HD control arms
58.75" Track Width
Construction:
Over 75 individual components specifically machined or fabricated for this application.
Not a single off the shelf part has been used
Acetyl GP bushings with 660 bronze oiled sleeves for maximum performance and zero deflection compared to the industry standard: polyurethane.
Double sheared and gusseted brackets for added strength
Grade 8 hardware standard
Positive and negative jounce bumpers to protect coilovers from excessive abuse
7075 T-651 Billet aluminum steering arms for strength and weight reduction
4041 Pre-hardened control arm mounts
Performance
Controlled roll center
Built in caster and camber street settings, easily adjustable for track setups
Optimal motion ratio for accurate spring ratings
Light weight components for lowest unsprung weight with out sacrificing strength
C6 Corvette spindles, hubs and lower ball joints
Performance improvements over stock corvette geometry
Increased negative camber gains
Increased wheel clearance (to control arms)
Increased strength
Drastically reduced bushing deflection
Installation
Lowered steering rack for additional oil pan clearance
Available in a standard or narrowed track width for lowered vehicles or wide front wheels
User friendly, serviceable design.
Easy adjustment and access of steering rack, sway bar, and coilovers
Reverse mounted upper control arm for simple caster and camber adjustments
Streamlined crossmember for maximum ground clearance and minimal visibility
Check out the video on the benefits of the FAST TRACK suspension system:
http://roadstershop.com/blog/2011/ro...ast-track-ifs/
Pricing and options here:
http://www.roadstershop.com/products...aro-suspension
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
