Old 06-10-2012, 05:05 PM
ProTouring442's Avatar
Default GM A-Body IRS
Since I have been working and reworking my '72 442 convertible for something like the last 15 years, I thought I might "upgrade" to IRS. Why not, right? I figure I will sell my Currie 9" to fund this little project.
So I figure I have six basic options.
1) C-3 Covette
pro: Uses the half-shaft as the upper control arm. This makes narrowing difficult, but it also alleviates the problem of upper control arm/frame interference.
con: The unit is difficult to adapt given the transverse spring, and trailing arms.
2) '69-'87 Jaguar
pro: Uses the half-shaft as the upper control arm. This makes narrowing difficult, but it also alleviates the problem of upper control arm/frame interference. Comes in an easily adaptable "cage." Center section is essentially a Dana 44. Readily available for little money.
con: Unknown axle strength. No trailing arm.
3) MN12 Thunderbird/Mark VIII
pro: Strong. Comes on a readily adaptable carrier.
con: It's 2" too wide. Not easily narrowable (cast lower control arms).
4) Mustang Cobra
pro: It's an inch or so narrower than the A-body rear. Comes on an easily adaptable carrier. Strong.
con: Known handling issues. Not cheap.
5) 200X GTO
pro: Easily adaptable. Inexpensive.
con: Strength (both the differential and the suspension components)?
6) Pontiac G-8
pro: Comes on an easily adaptable carrier.
Remember, this is a bit of a Pro-Grand-Touring car; a backroad burner, long distance tourer, and not an autocross machine.
I was leaning toward the MN12, but after reading about the Jaguar unit, I think it might be a good choice. It even has the right wheel bolt pattern. I think the adaption of a trailing arm to the factory A-body might help with wheel hop?
Anyway, looking for thoughts and arguments regarding any of these.
Shiny Side Up!
Bill
Old 06-10-2012, 10:13 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Check out these links, a bit of info, not real in depth, but a good starting point for research.
http://www.rodandcustommagazine.com/...n/viewall.html
http://www.hotrod.com/howto/hrdp_071...s/viewall.html
Did you consider a C4 Vette Rear end type of set up? The gear case / center section is braced with a torque arm (like a 3-link) and the wheels are set up like a 4-link. Yeah a real oversimplification, but I've heard that most mods that narrow the set up still retain good geometry with a hub to hub measurement as narrow as 58 inches .
These guys do a C4 Vette suspension on 50's trucks and tri-fives
www.hotrodjim.com/trifive_c4_grand_coil.php
And there are a few other shops that do custom C4 Vette set ups. They mostly cater to Corvettes only but some have done other projects.
http://uscorvetteconversions.com/
http://www.progressiveautomotive.com/
And one of the guys in our club has a 69 Camaro with a BMW 7 series IRS. He liked it because it had the huge brakes, and the right hub to hub for his project. He went with cantilever shocks in the trunk. Quite a project but it looks sick, and it handles great.
http://pacificfab.net/barry-camaro.htm
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 06-11-2012, 05:16 AM
The C-4 looks nice, but very pricey.
The more I read though, the more the GTO rear looks like a good choice. Though he's never posted anymore on it, DDT RCKT put one in a a '70-'72 LeMans (shares a frame with my 442). Here is the thread on it.
Hmmm.....
Shiny Side Up!
Bill
