Old 03-06-2006, 07:53 PM
Porterbuilt Porterbuilt is offline
Default What backspacing on a 67?
I have a 67 Camaro convertible with DSE 2" drop coils and 2" drop leafs. Who is running this set-up with 18s? and what backspacing are you using? The car will not be modified to make more room for a larger tire in the rear.
Old 03-06-2006, 09:38 PM
awr68's Avatar
awr68 awr68 is offline
18x8 w/ 5" bs and 245/40 tire on the front
18x9.5" w/ 5.5" bs (w/ disc brakes) and 275/35 tire on the rear or you can use a 275/40 to help fill the wheel well better on a 67-68, since it's a inch taller overall you will fill the wheel well a half inch more....but remember they will be taller than the front, so it's all in the look you are going for. I prefer for the front and rear sidewalls to be the same height....
Tony
'68 Camaro
Old 03-07-2006, 01:31 PM
mouthster mouthster is offline
Default poterbuilt
What up fool? Is this Nate Porter? This is you cous Nick
Old 03-10-2006, 04:11 PM
ls67 ls67 is offline
Default b/s
i went with 5 inches all the way around lowered 2 inches and 17 centerlines no problems detectable but she aint been down the road yet.
