Old 06-21-2012, 12:34 AM
tlillard23 tlillard23 is offline
Default ATS spindles and ABS questions
I have ATS spindles and GTO ls2 with all the harnesses. Trying to find out what kind of sensors I should get on the rear end that will match the ATS (corvette) spindles to go along with my 2005 GTO ECM/BCM.... Not sure if I will actually get ABS worrking, just want to order my rearend with the highest chance of it working.
Does the 2005 GTO have a 3 or 4 channel ABS system?
Does the GTO have the same reluctor as the ATS spindles\?
Old 06-21-2012, 08:17 AM
Blake Foster's Avatar
The only way that i know of right now is to upgrade the front hubs to ZR1 hubs, and then use our Chicane 9" floater with the matching ZR1 hubs.
you have to make sure the abs signal is compatable with the computer. i doubt the GTO computer would even begin to work as it needs alot of vehicle information to calculate all the parameters.
Blake Foster
www.speedtechperformance.com
