Closed Thread
Old 03-07-2006, 11:35 AM
4OfaKind's Avatar
4OfaKind 4OfaKind is offline
Default AWD Chassis for sale
Have to sell my project due to personal reasons.
So I am offering my chassis to a good home. would prefer someone buy it who intends to finish it, not strip it for the parts (though I can not control that).
Ok about the chassis:
It was designed to go under a Tri-Five Chevy. It is custom built from scratch from the ground up. Builder did not even have an original frame from which to start. Measurements were based on dimensions found in GM assembly manual here: Frame dimensions Full tube chassis designed to handle 1000hp w/o a roll cage. C4 Dana 44 rear and S10 4x4 front differentials. These are the only used parts on the chassis. the Cadillac transfer case and C4 quick ratio rack and pinion are new purchases.
You can view the chassis here: Chassis Pics
Deigned for a 4" engine set back for better weight distribution. Designed for 5.5" ride height on coilovers. Can be adapted to air bags. Frame rails widened to inner rockers to make room for drivetrain and exhaust. Will require floor modifications to fit, they include firewall, trans tunnel, and under rear seats above rear diff. Will accept stock fuel tank. No fuel cell required. Sold as pictured. Requires center bracing and mounts for transmission and body.
Asking $10,000.00 but will accept reasonable offers.
Old 12-26-2020, 09:31 AM
Mike Kelley Mike Kelley is offline
Default I am interested in chassis for sale
I am interested in chassis for sale, if is still available.
Mike Kelley cell 503-706-1400
Old 12-26-2020, 10:27 AM
Bad Bowtie Bad Bowtie is offline
Holy dead threads.... You do realize this was from Mar. 2006
Closed Thread
