Old 06-23-2012, 06:30 AM
Sieg's Avatar
Sieg Sieg is offline
Default Think your brakes are trick?
A lot of technology to absorb here:
Old 06-23-2012, 01:16 PM
Apogee Apogee is offline
Wow! Carbon/carbon or cabon/ceramic? That's a lot of little doo-hickeys going on...care to share what it's from?
Tobin
KORE3
www.kore3.com
Old 06-23-2012, 10:37 PM
Sieg's Avatar
Tobin
KORE3
Red Bull in the F1 pits at Valencia.
Red Bull RB8 - vented brake/wheel hub assembly
Red Bull have been forced to make changes to this wheel hub design - which we first featured at the Spanish Grand Prix - after suggestions the team were gaining an aerodynamic advantage from its clever design, by going against Article 3.15 of the technical regulations, which states that "any specific part of the car influencing its aerodynamic performance" has to be "rigidly secured to the entirely sprung part of the car" and must remain "immobile in relation to the sprung part of the car." In this drawing you can see the central hub has a series of small holes. Air is drawn through the brake duct and drum, passing the disc and caliper, and is then expelled through these holes which align with similar openings in the wheel rim. This reduces disruptive waste airflow inboard of the wheel and also reduces the transfer of heat between the rim and the tyre. But suggestions that the design was not purely for cooling, but rather could be used to energise airflow to the front wing, have led to Red Bull having to modify it in Montreal.
The F1 aerodynamisists continue pushing the envelope.
Old 06-23-2012, 10:58 PM
intocarss's Avatar
Live From Indy a few years ago
