Old 06-23-2012, 02:28 PM
Carbo Carbo is offline
Default L99 good choice for swap?
I have a 69 camaro and I'm considering doing the LS swap. Right now I have the opportunity to pick up a L99 all Aluminum 5.3 H.O engine complete with all accessories and harness with ecu, swap fuse an relay box, a 2wd 4l60e trans with new pump for $1700.00. The engine has 50k on it but I don't care about the mileage as I'll be having it rebuilt locally by an engine shop (looking for around 600 hp motor).
First, is this a decent motor to do a swap with?
Second, are there any concerns with this particular model..L99 vs an LS2 or LS7?
I haven't done a lot of research on this topic yet as I am just beginning to explore but if I can pick up a good motor and tranny for this cheap I want to know that it is worth it with an L99.
Thanks in advance.
Old 06-24-2012, 01:02 PM
rallystyle rallystyle is offline
l99 engine code is from a camaro. its like a ls3 with afm and vvt.
http://archives.media.gm.com/us/powe...10truck_us.htm
Old 06-28-2012, 07:45 AM
69-X44 69-X44 is offline
Looks like you have a L33. It will have an aluminum block and heads. The compression is higher and has different heads than the stock iron block LM7. I picked one up last year and will be putting it in my 69 camaro when the body is finished.
Good luck.
Old 07-01-2012, 10:12 AM
Thanks. Unfortunately the engine and trans are sold. I'm back to the shopping stage again.
