Old 06-23-2012, 03:45 PM
J-440's Avatar
J-440 J-440 is offline
Default Mopar FAST distributor
440 Chrysler with the FAST XFI system and duel sync distributor. Have followed directions to a "T" and this thing still won't start. On the ECU the red led marked "Crank" will not flash like it's supposed to as the engine is cranking. Ok, it gave me a CTS fault. Cool, that means the distributor is not lined up correctly. Well I've done what the directions said and still no fire. I've got both LED's on the distributor to light up, but still no deal. All of my sensors are GM and all the settings are correct so you Chevy guys can chime in if you want. Thanks again for the help.
68 Charger, 440SC, EFI, 6-speed
