Old 07-08-2012, 09:25 AM
BODYSHOPMARO's Avatar
BODYSHOPMARO BODYSHOPMARO is offline
Default 447 Erl Sleeved Ls Stroker
DECIDED TO SPIT THE MOTOR UP IF ANYONE IS INTERESTED SELLING THE SHORTBLOCK WITH BALANCER. YOU WILL NEED A OIL PAN. I HAVE OVER 8700 IN JUST THE SHORTBLOCK. ASKING 7600 SHIPPED I STILL HAVE THE REST OF PARTS STILL ASSEMBLED ON ENGINE IF INTERESTED, ONLY THING MISSING IS the intake. everything has been professionally ballanced, degreed, and assembled
CALL OR TEXT 317 385 8484
sleeved by ERL
ARP MAIN STUDDS
Wiseco Stroker Crank 4.125 4340
K1 6.125 H Beam Rods
Wiseco Piston Kit K462x155
Main Bearings Fm152m Coated
Rod Bearings Clevite Cb663hn Coated
Cam Bearings Dur Chp-23t Coated
Victor Gasket Set 95-3563
Pro Gear Timing Chain Pg4158
Mellings Select Oil Pump 10296 Ported
Arp Balancer Bolt
Arp Cam Bolts
Scoggin Dickey Block Plug Kit
Cometic Mls Head Gasket C5319-452
Valley Gasket Ms19308
Arp Head Studs 234-4317
bullet custom hyd roller cam 247 255 650 629 112 lsa will sound like heaven
lunati race hyd roller lifters lnt72532
NGK SPARK PLUGS
COMES WITH CAM SENSOR AND CRANK AND OIL PRESSURE SENSOR
ELDEBROCK HIGH FLOW WATER PUMP
ATI BALACER
KATECH TENSIONER
Its only money/ 68 camaro/ Rich Sliwinske(PRECISION ENGINE AND MACHINE) 447 ci ERL sleeved/ landspeed development ported heads L92s/speedtech subframe/DSE mini tubbs/
