Old 07-20-2012, 10:32 AM
JON Q's Avatar
JON Q JON Q is offline
Default Tr6060
Question, I have a chance to buy a tr6060 trans off a 2010 Camaro low mileage. Will this bolt on to an LS6 without modifications?
Jon
Old 07-20-2012, 10:33 AM
JON Q's Avatar
I forgot, I will be installing this on my 69 Camaro..
Thanks again for any input..
Old 07-20-2012, 05:06 PM
daytonayellaz daytonayellaz is offline
It will bolt up just fine. The bell housing and midplate on that trans is all one piece... unlike the earlier F-body T56 transmissions. You can run a twin disk ZR1 clutch in this trans. Its a little longer also. You will probably want to run a Magnum tail housing on it as well. I was going to run this combo in my 70 camaro and bought a Magnum instead. Im always trying different ways to make these transmissions more user friendly in our old cars. I have some pics of the camaro tr6060 with magnum tail housing if you wants to see what it looks like.
Old 08-04-2012, 10:21 AM
JON Q's Avatar
Travis, can you please post pic..
Jon
Old 08-06-2012, 09:11 AM
Here you go...this is a 2010 camaro TR6060 with a Magnum tail housing. Its actually a empty case I was using for mock up in my 70 camaro.
Old 08-07-2012, 02:34 PM
JON Q's Avatar
Thanks Travis!! PM sent...
