Old 07-23-2012, 05:52 PM
okyankee okyankee is offline
Default how much hp and tq till...........?
i have to box my 67 chevy swb frame? i got a 588ci engine in the works and want to know if i should box my frame and or roll cage it before hand. i need to replace the rear end to handle it, so i was wondering since i will make it shorter, how wide of a wheel and tire combo could i fit back there without chopping the frame. thanks for any help.
Old 07-26-2012, 06:52 PM
no one ever work on these trucks? thanks.
Old 07-27-2012, 01:45 PM
gray776's Avatar
gray776 gray776 is offline
I would try this site:
67-72chevytrucks.com
LOTS more info on these trucks over there!
Jason
Old 09-06-2012, 05:32 PM
gnx7's Avatar
gnx7 gnx7 is offline
If you are putting a 588ci setup in there you should reinforce that frame as much as possible.
I know I'm boxing my Chevelle frame rails and reinforcing the rear trailing arm pickup points.
Old 09-07-2012, 02:19 AM
4mm 4mm is offline
It also depends on what tire you will use. The more the tires hook the more you will twist and torque the chassis.
Old 09-11-2012, 02:49 PM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Depending on your budget, something you may want to consider if you are planning on putting serious horsepower or cornering force through your truck...
http://www.roadstershop.com/products...ick-up-chassis
Right now we are running 345's on all four corners and a 704hp/671lb ft LS motor.
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
