Old 07-25-2012, 12:51 PM
Jmastersinc Jmastersinc is offline
Default 2002 6.0L from 3/4 burb to 57' chev PU
Hay guys, I just found this site and am glad I did! I have a 2002 3/4 ton suburban with a 6.0l. It has around 145,000 on it and I hear a tick on cold starts. My plan is to get a 6.0 take out, do a mild rebuild, put it in the burb, take the burbs 6.0 re build it and put it in my under construction 57' Chevy pickup, I also plan on puttig a gen 2 Camaro front clip, my thinking is this will make the swap easier, give me disks and a-arms and sway bar ect. I am just starting to research the 6.0, looking I see if this is a good motor, what's the take out prices, rebuild kit price ect
Thanks and great forum!
Old 07-25-2012, 01:54 PM
rallystyle rallystyle is offline
ls motors are good motors. i would try ls1tech.com for more info on the ls motors
1970 El camino
1969 camaro
1996 civic
Old 08-01-2012, 04:48 PM
aray327's Avatar
aray327 aray327 is offline
You can likely find pull out motors for less than what a rebuild would cost. Drop a complete motor in each truck. I've heard pull out long blocks for as low as $80. I have purchased multiple complete motors with harness/computer and trans with low miles for $1,500 to $2,500.
I have a 55 big window I plan to do as well, except changing the cross member to hang all new (new to me!) suspension from. I don't want to mess with cutting up the whole clip and making new attachments for bumpers and sheetmetal.
one day my ride WILL be as nice as yours...
Old 08-06-2012, 11:16 AM
Check your local LKQ for engines and pullouts. I put (lots) of LS motors in older cars! 5.3, 6.0's etc. Easy to make power with and tons of aftermarket parts to make the swap pretty straight forward.
Jeff Allen
J2 Speed and Custom
