Old 07-25-2012, 06:42 PM
xssive99 xssive99 is offline
Default GMPP L92/L76 Aluminum intake, 92mm TB, 4150 elbow, Mast rails, FIC 160lb injectors
All of this is brand new, never been run.
GMPP L92/LS3 intake manifold, fuel injected. GM part # 25534416 - SOLD!
AAron's 6061.com intake elbow. Standard height, 90 degree, forward facing, bung plate - 190$
Mast Black Label fuel rails - 260$ with all the line and fittings shown (that over 160$ in plumbing alone. Dual -8 feeds with a -10 Magnafuel Y feed. This is the most efficient highest flowing configuration)
FIC (fuel injector connection) Flow Matched Bosch 160 High impedance injectors. EV1 connectors. - 900$ for the set of 8. Never seen fuel!
92mm Fast knockoff TB - 160$
I will package price things!
Old 07-26-2012, 08:37 AM
8mywal8 8mywal8 is offline
Will you separate? Might have interest in manifold?
Old 07-26-2012, 11:58 AM
Yes I will separate everything
Old 07-26-2012, 12:55 PM
NvrDun71 NvrDun71 is offline
Do you happen to know if the Mast rails will work on a stock L76/LS3 intake? Happen to have the Mast part #? If they will work I am interested
71' Nova - LY6, T56
Old 07-26-2012, 07:29 PM
Yes they will work with a stock plastic manifold with short injectors, that's what they were intended for. I don't have the part # because Mast doesnt make them anymore that I know of
Blake
