Old 07-26-2012, 11:17 AM
6camaro9's Avatar
6camaro9 6camaro9 is offline
Default Question about fuel lines?
I am getting ready to redo the fuel system on my camaro and was wanting to know what size line would be best to use -6an or -8an. I am currently running a 400 small block with a Holley 750 carb. Thanks
Old 07-29-2012, 08:32 AM
ROBS6T8's Avatar
ROBS6T8 ROBS6T8 is offline
I believe the 3/8 line would be plenty. Now what that boils down to in AN measurements would be the -6.
Old 07-29-2012, 10:44 AM
Flash68's Avatar
Flash68 Flash68 is offline
I'd wanna do the lines once so if you have power goals that are much higher sooner or later, maybe plan with that in mind and it may want you to do -8?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-29-2012, 11:17 AM
LSX67 LSX67 is offline
I have a LS7 w/ cam, intake, long tube headers and tune running -06 fuel line with zero problems.
