Old 07-27-2012, 03:20 PM
snappytravis's Avatar
Default Fuel tank and pump
Looking at the Ricks Vaporworks tanks, pretty nice piece, I am planning on running ls3 with maggy or vortech supercharger, What would be a good tank and pump setup to feed this baby, I was thinking vaporworks tank with ls9 pump and msd controller, I also saw the aeromotive pumps, Please shoot me in the right direction in tank pump would be clean install,
Thanks you guys rock!
Old 07-27-2012, 04:06 PM
Musclerodz's Avatar
the ls9 pump won't work with the vaporworx, they use the ctsv pump, and would also use the vaporworx controller. That would be my choice along with the maggy.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-28-2012, 11:23 PM
CarlC CarlC is offline
Mike is correct. The VaporWorx design is a system that is meant to be used only with the Gen5 LS3, Gen5 ZL1, or CTS-V fuel module. The engine and intended use of the car will dictate which is the most appropriate choice, but for healthy supercharged engines the CTS-V is the better choice for most applications.
However, before making any expensive fuel delivery choices regarding the above, it's recommended to consult with VaporWorx. It is much less expensive and painful to figure it out right the first time.
http:www.vaporworx.com
