Old 07-30-2012, 09:17 AM
snappytravis's Avatar
Default motor mounts solid or rubber
I am installing a ls3 into 69 camaro with morrison chassis, I set it in with regular small block chevy block mounts and adapter plates but it touches the tube on the rack and pinion, do you think I need solid mounts I plan on supercharging it and should be around 750 horse, thanks
Old 07-30-2012, 09:34 AM
Ron in SoCal's Avatar
Trav - my AME out of the crate was set up for 4 degrees down which cleared the rack. When set up at a more optimal 2 degrees we had to do some massaging and small spacers to clear the rack. Also used the AME motor mount plates and poly mounts. Check to see if your oil pan is too deep in which case you can look at more front/shallow options too.
Hope this helps!
Ron in SoCal
69 Camaro in progress
