Old 08-01-2012, 12:55 AM
FETorino's Avatar
FETorino FETorino is offline
Default Anyone run a Modern Driveline clutch master linkage set up
Probably not since it's for a Ford and not a Camaro but I thought I'd ask.
http://www.moderndriveline.com/catal...ic_masters.htm
Rob in SoCal
Old 08-01-2012, 01:51 AM
4mm 4mm is offline
I had one in a 70 Mustang I sold a while back, no issues.
Old 08-01-2012, 09:23 AM
EBMC's Avatar
EBMC EBMC is offline
We replaced " one of the other guys" setup with this in a Mustang that was brought into the shop with a stiff pedal.Some manufactures sell hydraulic conversion kits with no regard for proper geometry. This is actually thought out and worked very well.Night and day difference.
Steve Keefer
Old 08-01-2012, 10:00 PM
FETorino's Avatar
Thanks for the feedback. WTF something that will actually just bolt in and work it can't be true
Rob in SoCal
Old 08-02-2012, 04:55 PM
65 347's Avatar
65 347 65 347 is offline
I have this set up on the mustang, you'll love it. Change out the plastic reservoir for a billet aluminum one.
Mike
