Old 03-11-2006, 10:31 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default GM Wiper Switch wiring ?
Anyone know where I can find wiring diagrams for a GM dash mount wiper switch ?
www.hotrodderjournal.com
Old 03-13-2006, 01:28 AM
jannes_z-28's Avatar
I have the GM diagnostic CDs
The diagram are different depending on the car it came from, so if you give me that I can give you a diagram of it.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 03-13-2006, 07:35 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
I have fooled around with these. They run off grounds. The switch itself must be grounded. The high/low speed are also grounds that go out to the motor.
Not sure what you are wanting to do, but I have found you can use a late model column switch and run it to ground instead of power (as the late models us a power signal to trip the motor) and it will control and old wiper motor.
Old 03-13-2006, 08:05 AM
What I could use is the switch operation of a 86 Buick column wiper switch and a 80 buick dash mount.
Trying to get a dash switch (ground pulse) to work in a column switch car (power switch).
I got everything to work but the park mode so that it pulls the wiper down under the hood. I think it's tied into somehow the washer motor but I can't be sure................damn GM why couldn't they just stick with ground pulses......
