Old 08-08-2012, 10:19 PM
55vic 55vic is offline
Question 1955 Ford overdrive
I am a new member to the forum.
I've recently purchased a '55 Ford with 3 speed manual and overdrive.
Can anyone tell me the correct proceedure for using the overdrive? e.g. Do I de-clutch to engage/disengage? What speeds are recommended for the o/d use? etc
Old 08-09-2012, 07:55 AM
takid455 takid455 is offline
works on switch mounted under dash IIRC. that activates the solenoid on the back of the trans. Believe it disengages when the brakes are engaged. Have one on the shelf I picked up for a 56 F250.
