Old 03-12-2006, 06:41 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Alignment Help
Whats going on Lat-G? I need to know how do I make sure my subframe alignment is right on my 67 camaro? I have put new body bushings in and I guess you need to make sure that the subframe is aligned right, so how would one measure to make sure that its right. Thanks guys!
-Brian
WicKeD
Old 03-12-2006, 07:24 PM
coolclassiccars's Avatar
coolclassiccars coolclassiccars is offline
Default alignment of sub
the stock sub frame has a hole right beside the driver side body mount,i believe is 610 thous,just over a half inch,in the driver side first ,the pass side is semi slotted,have the sub sorta loose for this. that will get you close enough,that's how gm did it.the other way is to measure from the lower ball joint grease fitting to the front of like the spring perchbolt area some place back there that has equal points.we use an alignment machine with lazers on the wheel area to see how far the thrust is off,been doing computerized alignments for 7-8 years now hope this helps.
Old 03-12-2006, 07:32 PM
WicKeD_SS's Avatar
Cool thanks for your help, Is this something I can do or do I need to take it somewhere? Right now the dog house is off the car, is now the time to do the alignment or should I have the dog house on?
Thanks for your time,
-Brian
WicKeD
