Old 08-13-2012, 07:48 PM
chevmech1969's Avatar
chevmech1969 chevmech1969 is offline
Default Scored more parts. maybe time for a build tread?
Well awhile back this year i picked up a T56, and associated clutch parts, and a ls1 harness and computer for a steal of $320
Had a buddy that had some more goodies call and i now have a 6.0L lq4, a set of ls1 heads with comp springs that match the xr281hr for $700.
now Just need some L92 heads and ls3 accessories and intake, then maybe ill start a real build thread, vrs just collecting parts.
I think it should all work good in my 69,
p.s. what do you think of the cam and 6.0l with l92 heads, im sure it will break the high 400's in hp Thoughts? comments? concerns?
2200-7200 Valve Timing: 0.006 Lobe-Center Angle: 112 Intake Centerline: 110 Valve Lash: Intake-Hyd Exhaust-Hyd Duration: Intake-281 Exhaust-283 Duration at .050" Lift: Intake-228 Exhaust-230 Valve Lift: Intake-0.571 Exhaust-0.573 Lobe Lift
Johnson's Rod'Z
A man with few vices, has damn few virtues.-Benjamin Franklin
