Old 08-20-2012, 06:04 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Lokar Shifter boot help.
Im needing to know any tips on installing this Lokar shifter boot and ring. Didnt know if Im to drill holes threw the boot where the ring holes are or just tuck the boot under the ring when snug, maybe over lap the boot and cut off whats past the ring.... And whats the best way to drill threw the carpet and juke with out it getting bound up on the bit or screw?
Thanks for any help!
-Brian
WicKeD
Old 08-20-2012, 06:30 PM
protour73 protour73 is offline
-Brian
WOW, no response to this yet?
First thing I did was look for instructions by Lokar on the internet and couldn't find any.
I have called Lokar a few times about products that I've purchased and they are very helpful. Call them, tell them what you have and they will surely give you installation advice. Better than messing up a brand new part, right?
Old 08-20-2012, 07:36 PM
WicKeD_SS's Avatar
Yeah the boot didnt come with instructions, and I really didnt think about calling them.... But I will thanks for the Tip!
WicKeD
Old 08-20-2012, 08:07 PM
canrc canrc is offline
Dont know if it helps but I am using the lokar billet ring but had a boot made and didn't use theirs -- I drilled through the boot.
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 08-21-2012, 05:37 PM
WicKeD_SS's Avatar
Great, think Ill do that. Thanks
WicKeD
Old 08-22-2012, 02:31 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Put your ring in place then take a very sharp drill bit and push hard to drill holes thru floor,
place boot over shifter and get it at the look you want ( short or Tall )
place ring over edge of boot an use a hole finder (awl, scatch awl, pick ) to locate holes
run screws thru holes, If there is material showing around ring carefully trim with a blade.
stand back and admire your work
TRACY WEAVER
www.recoveryroominteriors.com
Old 08-22-2012, 04:22 PM
^^^^ I was hoping the "King of Interiors" would chime in with great advice, thanks Tracy. There you go Brian!!
Old 08-22-2012, 06:29 PM
WicKeD_SS's Avatar
Great! Ty I just wanted to make sure I did it right so thanks for the info.
WicKeD
Old 08-22-2012, 10:47 PM
Supporting Vendor
Glad to help, I only check in you guys every couple days to see these type of questions, So if im slow to help with a answer, You know why
TRACY WEAVER
Old 08-24-2012, 10:42 AM
79 Camaro 79 Camaro is offline
On my lokar boot I notched the boot around the screw holes and then using contact cement glued the boot to the underside of the ring. Doesn't move around even when I take it off.
