Old 03-13-2006, 07:34 PM
MadMaxx MadMaxx is offline
Default For sale:7004/Richmond 5spd Tubular Crossmember
New in the box with p/n 6073 frame adapters!! $150, I'll split shipping to lower 48 states.
Chris Alstons Chassis Works
P/N 6068
700R4, RICHMOND 5-SPEED CROSSMEMBER FOR 7701
Obtain maximum header clearance with our tubular transmission crossmember designed for our Number -7701 front frame. It bolts to mounts welded to the frame assembly. This crossmembers has a black-powder-coat finish and is for use with Richmond 5-speed transmissions. It can be used with the factory frame when used with Number-6073 frame adapter.
