Old 08-21-2012, 06:28 PM
xssive99 xssive99 is offline
Default New: 377" LSX Shortblock : Callies Magnum XL, GRP Rods, Wiseco...
377" CI LME Forced Induction Shortblock - Ready for 1500HP
New 6.0L Iron Block direct from GM
* 4.030" Bore
* ARP Main Studs
* Durabond Cam Bearings
* 9.230" Deck height
* 9.0:1 Compression
Callies Magnum XL Crankshaft (2900$ new)
* Stroke 3.700"
* 2.000 Rod Journal Diameter
* LS1 Main Diameters
* Post Keyways
* No reluctor wheel
* Balanced to 1/4oz tolerance
* DART Oil Shedding Coating
GRP 1500 SERIES Aluminum Rods (1300$ new)
* 3/8 ARP 2000 bolt
* 6.125 Length
Wiseco Custom Piston (1100$ new)
* 4.030" x 1.250" x .927" x -17cc
* Coated Skirts
* Lateral Gas Ports
* Heavy Wall Tool Steel Wristpin Upgrade
* NPR GFX ring pack .047"/.047"/3mm
* .060" quench with .050" gasket
* .0045" Piston to Bore Clearnace
This is a new, never been fired shortblock!
All machine work was done by Bryan at LME in Houston. Ive attached the machining invoice and build sheet. Ive got over 8400$ into this shortblock as it stands. This not your everyday run of the mill mass produced shortblock. It was built to handle everything a PT-101 could throw at it, and make over 1500hp reliably.
Looking for serious buyers, not tire kickers...
6800$
Old 08-21-2012, 09:30 PM
g356gear's Avatar
g356gear g356gear is offline
A thing of beauty. GLWS!
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-23-2012, 09:07 PM
8mywal8 8mywal8 is offline
This is a great seller. His stuff is top notch. I have bought numerous parts from him.
